It is currently Sat Sep 20, 2025 5:07 am
PostPosted: Wed Nov 11, 2020 9:01 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
To avoid adding moisture to a neck, what epoxy (or other glue) are you using to glue the fingerboard to the neck?
I was using "All Wood Epoxy" but it has gotten overly expensive.
PostPosted: Wed Nov 11, 2020 9:39 pm
I use West system - the same stuff I laminate sides with. It takes a while to set up, so I let it cure overnight. It doesn't take much to glue a fingerboard, so I measure and mix it in the 1 oz. medicine cups.
These users thanked the author Clay S. for the post: Ed Haney (Thu Nov 12, 2020 6:05 pm)
PostPosted: Thu Nov 12, 2020 1:21 am
First name: Tim
Last Name: Allen
City: San Francisco
I also use West System. It dries hard. I use a $15 electronic scale from eBay to measure a small quantity.
Tim Allen
"Never hurry, never rest."
These users thanked the author TimAllen for the post: Ed Haney (Thu Nov 12, 2020 6:05 pm)
PostPosted: Thu Nov 12, 2020 2:36 am
Smith and co Tropical Hardwood Epoxy.
Use a small toothing plane on both surfaces.
These users thanked the author Colin North for the post: Ed Haney (Thu Nov 12, 2020 6:06 pm)
PostPosted: Thu Nov 12, 2020 7:53 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
System Three T-88. The gun and mixing tips make it very easy and fast to use, no measuring. Now carried by Stew Mac.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: Ed Haney (Thu Nov 12, 2020 6:06 pm)
PostPosted: Thu Nov 12, 2020 1:06 pm
I stopped using epoxy and went back to tite bond
I don't think the moisture is an issue.
These users thanked the author bluescreek for the post (total 2): muse (Tue Nov 17, 2020 11:53 pm) • Ed Haney (Thu Nov 12, 2020 6:06 pm)
PostPosted: Thu Nov 12, 2020 2:58 pm
+1.
Before that I was using System III.
These users thanked the author SteveSmith for the post: Ed Haney (Thu Nov 12, 2020 6:06 pm)
PostPosted: Fri Nov 13, 2020 7:49 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
It may not be an issue if you are using a double action rod. But any water-based glue will introduce a small amount of backbow into a flat neck. You can level it out or adjust it out. I prefer to keep the neck flat.
PostPosted: Sat Nov 14, 2020 8:56 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
System 3, but now experimenting with gorilla clear poly glue. Its cheap, readily available , comes in a small bottle . easy to spread with an acid brush. Long open time., and sets up hard at 70 F in 2 hrs . I laminated 2 pieces of katalox to a red oak body for future plane. It also works well for gluing plastic binding. to wood. Will start testing soon on FB. Called gorilla and was told it delaminates with heat at 175 to 200 deg F
These users thanked the author Ernie Kleinman for the post: Robbie_McD (Sat Nov 14, 2020 9:39 am)
PostPosted: Sat Nov 14, 2020 11:30 am
First name: Terry
I won't get any "cool points" with this, but I get a $6 DevCon double syringe from my local Ace Hardware when I run out (which isn't too often). I only use epoxy for gluing fretboards, gluing in carbon fiber rods and inlay. I like this stuff cuz I don't have to measure, it's cheap, has a 30 minute working time, and is a 2-ton formulation.
PostPosted: Sat Nov 14, 2020 3:06 pm
I got away from using the quick set epoxies. They never seemed to get really hard, like West system.
PostPosted: Mon Nov 16, 2020 6:52 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Update. After gluing a maple FB to a piece of pine using gorilla clear poly glue. I tried to remove the fb a day later at 225 F using a 1.25in by 18 in silicone heating blanket . I managed to get 2 palette knives inserted and thats as far as we got. Gorillas website says its moisture an water resistant. So this will work well for coco FB, but may be difficult to remove in the future . Will stick with Fish glue for fb . gluing. This poly glue will work well for plastic bindings and waxy / oily woods like cocobolo. And jonting waxy/oily woods
PostPosted: Mon Nov 16, 2020 8:41 pm
Last Name: Beaver
City: Lake Forest
I've had one problem using titebond. I used to much glue, clamped poorly, and took out of the clamps way to soon. I make sure I use good technique now, still use titebond, and dont have any troubles.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Nov 16, 2020 9:46 pm
Last Name: Beaver
City: Lake Forest
If I was to use epoxy I would use System Three Clear coat. T-88 is a structural glue, for weight-bearing, which would be fine, except some of the structural epoxies tend to turn greenish after time. Not sure about T-88 but a phone call to System Three should tell you.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Nov 17, 2020 7:58 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Like Ernie I use the clear Gorilla glue .It bonds without moisture,unlike the original
Brown Gorilla glue.
Mike Collins
